Gollum Posted October 8, 2004 Share Posted October 8, 2004 ok, i'm sad now. I went to start my z today (it's complete, woohoo) and it turned over and didn't start in about 4 seconds of turning over. So i stopped, since i didn't want to burn out the starter or anything stupid like that. I tried a couple more times, about 3 more times, and i figured i go and double check the connections on the fuel pump (since i couldn't hear it at all, wich i thought was strange). All looks good and i remember that there was NO fuel in the system, so it probly just has to pump fuel through the lines wich might take a while. So i go to start it and it won't turn over. The starter wouldn't make a single sound. It didn't turn at all. All i heard was that click (i forget what clicks, so sue me). I turn again and again and all i hear is click. It's not the battery, i tried jumping it. So, and bright ideas? I really could use some help. I'd like to have the car running by tomarrow (friday). Quote Link to comment Share on other sites More sharing options...
Guest jer Posted October 8, 2004 Share Posted October 8, 2004 multiple clicks usually means battery, and one click unfortunately...usually means starter. and thats all i know about that. Quote Link to comment Share on other sites More sharing options...
BleachZee Posted October 8, 2004 Share Posted October 8, 2004 Get a small hammer and hit the side of the starter and the start solinoid. ...try starting again after spraying some staring fluid in the throttle body with the throttle open. Hook up the intake tube again before cranking. Quote Link to comment Share on other sites More sharing options...
Gollum Posted October 8, 2004 Author Share Posted October 8, 2004 will try for sure. A friend of mine used to work at a nissan dealer back when the z cars where popular and he was saying that he doesn't think it's the starter. He was saying that it's rare for a starter to just go out like that. So was almost certain it's wiring somewhere. I'll keep at it. Quote Link to comment Share on other sites More sharing options...
Gollum Posted October 11, 2004 Author Share Posted October 11, 2004 Ok, i changed the ignition over since the only key i had was REALLY warn down, like you could pull the key out at any stage. Now it turns over again (w00t), but the fuel pump still ins't turning on. So i'm going to figure out my electrical issues today with a friend's multimeter. I'm really glad i found out why it wasn't turning over. This really made my day. Quote Link to comment Share on other sites More sharing options...
Gollum Posted October 14, 2004 Author Share Posted October 14, 2004 WOOHOO! She's alive. I got her started, and with open headers she's a screamer. I'm taking it to the muffler shop tomarrow as long as i can take the cat off my gold ZX. So, this brings me to my next question. Is the o2 sensor in the exhast on the ZX series z cars? I'll ask my muffler guy about it tomarrow. I hope i has o2 sensors to put in. I'd asume he does. Any knowledge would be appreciated. PS the alternator belt broke on me, so i replaced all 3 belts beucase they're cheep. I also got all my interior put in. The car is really coming together. I've been at it for 7 days and i've put in at least 50 hours or so. But i've gotten alot done in that time. Let me see if i can list everything that i had to fix and.or switch over from my other ZX. Alternator Shifter overflow tank headlight mounts carpet seats ignition center console (all of it) fuel pump fuel pressure regulator idle sensor engine cooler belts driver side window driver side lock mechanism door interior panels t tops -didn't need to, but i know mine work. I'll kep both sets heater inlet hose full intake system hood springs - i HATE these now rear interior panels - rear, rear left, rear right t top cover sraps under dash interior pieces I'm sure there are a few things i'm forgetting. I might edit this later if i think of anything else i've done. There is still plenty to do though. But the car looks about 90% complete, if not more like 99% to someone who doesn't know any better. Quote Link to comment Share on other sites More sharing options...
Gollum Posted October 20, 2004 Author Share Posted October 20, 2004 ok, so the o2 sensor what hooked up all along. I'm just blind. Now, she's starting REALLY ruff in the morning. Takes about a good 5 tries to get her started, although she started just fine this morning first try. It'll get up to about 500 rpm then die. Keep doing this then start and rev to like 2k and fall back to a low idle. Any ideas? The sensor light on the dash turns on once the car is started. Not the check engine, but the sensor light on the left of the cluster. Anyone know wich sensors this thing is hooked up to? PS. Anyone in the SF bay area have a first gen z car i can ride in some time? I need to find a local club. I'm thinking if i can fit into one comfotbly i might sell this zx and buy a first gen Z. Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted October 20, 2004 Share Posted October 20, 2004 If you're ever in FAIRFIELD you can have a ride anytime.... LARRY Quote Link to comment Share on other sites More sharing options...
Gollum Posted October 20, 2004 Author Share Posted October 20, 2004 omg, fairfield is about a 20 minute drive. I'm over near richmond. Know of any local z clubs? Quote Link to comment Share on other sites More sharing options...
