auxilary Posted October 17, 2004 Share Posted October 17, 2004 any tips on getting the braided SS line into the damn fitting? it's like a square peg through a round hole! Quote Link to comment Share on other sites More sharing options...
GAZRNR Posted October 17, 2004 Share Posted October 17, 2004 I had the same frustrations. I solved the problem by using 1/2 wide masking tape, here is what I did: 1) put a tight 1 time around the ss hose where you make the cut, 2) use a cut off wheel or dremel to get straight cut, 3) lube up the inside of the fitting and use an air ratched to get it seated on the hose, 4) lube up the threaded end and watch to make sure you do not "push" the hose out of the fitting. Once you do a couple you will get the hang of it and be very pleased with the finished product. Rusty Quote Link to comment Share on other sites More sharing options...
blueovalz Posted October 17, 2004 Share Posted October 17, 2004 A lubricant (oil) is a key, both inside the hose and outside. I like to mark the SS braid before getting any oil on it so that I can visually see if the hose has been pushed outward of the AN housing while tightening the housing. I clamp the housing in a vise, and then turn the fitting "in" rather than the other way around, and this seems to be the easiest way. Quote Link to comment Share on other sites More sharing options...
auxilary Posted October 18, 2004 Author Share Posted October 18, 2004 wow, that was easy. did exactly what both of you said to do (and borrowed friend's AN vice clamps that summit carries). taped it off tight, used a dremel to cut the line, not a single strand of SS popped out. That did, however, cost me 1 dremel disk per fitting, lol. Oiled up the line, fitting, used a 3/4" ratchet on the outer clamp, it went right on. Nice of summit to reverse thread'em too, so when you're screwing the line in, it doesn't pop back out. Quote Link to comment Share on other sites More sharing options...
