Swapping gears in an R200
zthis
Sure. Same way that the 1st GEN 300ZX LSD center can be swapped. The only thing that might need to be changed is the pinion yoke. I currently have an 85 300ZX 3.54 geared 12mm R200 in my car. I had to change the square yoke to the round one for crossmember clearance. Other than that, everything else is the same. If you get it from a CV equipped car, you will need the stub axles from the 1st gen R200.
