(did a seach with noluck)what do i do with the extra wires??
MaTTSuN
i got my turbo motor in my 77280z and all i need 2 do now is hook up power 2 the computer. there are only 4 wires from the 280z harness for power
2 BLUE
RED
GREEN
and 7 from the 280zxT
WHITE
GREEN
YELLOW
BLUE/RED
RED
BLACK
BLACK/WHITE
does anyone know whow 2 hook these up? there is also another plug comming off the harness for prob the ignition the turbo harness has a 6 wire conection but the 280 has 4. i searched all over but did not find a thing
I'm not sur if this is what you are looking for but here's the wiring for the 280zxt. I hope this helps
You need to get a Haynes manual for ’79 to ’83 280ZX. This is the one with the red cover. Look on page 252, this is the wiring diagram. You will see 3 plugs labeled “1,2,3†with circles around the numbers. This is at the lower lefthand side of the page.
The wires are as follows:
Plug 1= BR 12v power source. Positive
G 12v power source. Positive
Plug 2=Y start signal (+)
GL ground for inhibitor switch
YW speed sensor (not necessary)
Y A/C signal (+)
YW coil (-)
B fuel pump ground if using modulator
Plug 3=LR fuel pump relay
G ignition .signal (+) for air regulator
W not used
Y not used
BW ignition signal (+)
hmm not sure, the only wires that are not going 2 anything are the B/R Y W and G maybe those 4 hook up 2 the 4 from my 280z computer power wires? but those are 2 Blue Red and Green
i know someone has done this swapi wish i could find out how they go, its the last link in my chain of parts and time 2 get my car on the road
