Ferd/289 Posted December 1, 2004 Share Posted December 1, 2004 How can I check to see if the interior of the tank is rusty and needs work. Car has been sitting in a garage and I drained the tank years ago. I heard of a process that corrects a rusty interior on a fuel tank. Anyone know what that is? Ferd Quote Link to comment Share on other sites More sharing options...
Guest Magnum Rockwilder Posted December 1, 2004 Share Posted December 1, 2004 You can remove it and "boil" it with muriatic acid and then use a neutralizer afterwards. You can get all the stuff needed at a swimming pool supply store. You can also use electrolysis if you can find a large enough tub to submerge it in. Quote Link to comment Share on other sites More sharing options...
Guest DiZeased_240 Posted December 1, 2004 Share Posted December 1, 2004 Try this kit from Eastwood. I've heard it works well. No experience with it though. http://www.eastwood.com/shopping/product/detailmain.jsp?itemID=382&itemType=PRODUCT&RS=1&keyword=gas+tank Quote Link to comment Share on other sites More sharing options...
Guest 240zJake Posted December 1, 2004 Share Posted December 1, 2004 I just took pea gravel and shook it in the tank untill all the rust rubbed off then used a gas tank sealer, I only had moderate to light rust though Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted December 1, 2004 Share Posted December 1, 2004 I took it to a radiator shop and boiled it out (3 times) then used the POR15 gas tank resto kit. Inside it is shiney silver & sealed. I then undercoated the outside of the tank before reinstalling it. A bit of work, but it is worth it. Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted December 2, 2004 Share Posted December 2, 2004 See if you have one of these in your area. http://www.gastankrenu.com/ They do an awesome job and it is guaranteed for life. Quote Link to comment Share on other sites More sharing options...
datsunlover Posted December 2, 2004 Share Posted December 2, 2004 As for 'seeing how bad it is' it's only two bolts holding the straps, and two rubber lines/filler neck.. I had mine off the car in about 45 mins, not knowing what I was doing! I had some bad scale.rust in there, so I sloshed a bunch of varsol around, and left it sitting for a few days. I did this 3-4 times, and it cleaned up good. Didn't have a problem all summer with cloged filters or poor running, so I guess it's ok. Quote Link to comment Share on other sites More sharing options...
Synlubes Posted December 2, 2004 Share Posted December 2, 2004 I have used this product (see link) in my tank regularly to keep rust from being a problem. It comes in a spary can as well as a 1/2 gallon bottle. http://www.amsoil.com/products/amp.html My car is parked more than it is driven. I had problems with rust in the tank many years ago. Started using the product then with very good results. Never even droped the tank, although I did change a few fuel filters until rust problem cleared up. I even use this to start my car after it has set for long periods of time and the fuel evaporates from my weber carbs. This stuff burns so clean, I can literally run my car off this stuff. It` good stuff! Quote Link to comment Share on other sites More sharing options...
