Guest tony78_280z Posted December 9, 2004 Share Posted December 9, 2004 Supose I wanted to replace my fuseable links with actualy fuses. Like maybe a little fuse box. What size fuses would be needed? Thanks Quote Link to comment Share on other sites More sharing options...
VRJoe Posted December 10, 2004 Share Posted December 10, 2004 Here's a link to give you all the info you need. http://www.zcarcreations.com/howto/maxifuse.htm - Joe Quote Link to comment Share on other sites More sharing options...
DaleMX Posted December 10, 2004 Share Posted December 10, 2004 Well, I did it also but I think it turned out kinda getto. Here's my breakdown. http://www.circuitflex.com/Fusible_Link3.html Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted December 10, 2004 Share Posted December 10, 2004 Thanks good info Quote Link to comment Share on other sites More sharing options...
spiff Posted October 1, 2013 Share Posted October 1, 2013 Hi, what size fuse should I install for the power supply to my ECU? I no longer have the fusible link since swapping to the L28ET with harness and I guess I should have a fuse to protect the ecu.... Quote Link to comment Share on other sites More sharing options...
ISPKI Posted October 9, 2013 Share Posted October 9, 2013 Spiff - Look up the amp rating for the wire gauge size, then get a fuse that is a little less than that (Example: a wire that carries 20 amps should have a 15 amp fuse). Tony - I purchased a Blue Sea Systems safety block 150 . It is a very high quality unit that takes 4 MIDI/AMI fuses which are perfect for handling the amps on our fusible links. It is designed for marine application so it is water proof and corrosion proof with everything being stainless steel. It also has space for low amp blade fuses. It is larger and more expensive than your usual ebay blocks though, but it can also handle alot more than cheaper blocks and it will last alot longer. I had one of those scosche audio style blocks and it survived for a few months before all the contacts wore out and would not hold the fuses any more. See This Link for the atlanticz guide on swapping your links. Their guides are top notch. Quote Link to comment Share on other sites More sharing options...
z240 Posted October 10, 2013 Share Posted October 10, 2013 Absolutely concur with the Blue Sea products. It will outlast your car. Worth every penny in the long run. Quote Link to comment Share on other sites More sharing options...
