Fuseable links
Guest tony78_280z
  • 8 years later...
Spiff - Look up the amp rating for the wire gauge size, then get a fuse that is a little less than that (Example: a wire that carries 20 amps should have a 15 amp fuse).
Tony - I purchased a Blue Sea Systems safety block 150 . It is a very high quality unit that takes 4 MIDI/AMI fuses which are perfect for handling the amps on our fusible links. It is designed for marine application so it is water proof and corrosion proof with everything being stainless steel. It also has space for low amp blade fuses. It is larger and more expensive than your usual ebay blocks though, but it can also handle alot more than cheaper blocks and it will last alot longer. I had one of those scosche audio style blocks and it survived for a few months before all the contacts wore out and would not hold the fuses any more. See This Link for the atlanticz guide on swapping your links. Their guides are top notch.
