?? on 6.0 and 8.1 chevy engines
Tim240z
Anyone know if any of these motors from the 2000+ chevy trucks and vans have regular cable throttles, instead of drive by wire throttles. (looking to retrofit my 71 Cheyenne 20. I would like either of the 2 above, or an LS1 with overdrive auto. Any reason why the LS1 would not be a viable option in a 3/4 ton truck?
Thanks,
Tim
I've had a 2000 suburban and a 2000 Z 71 pick up. Both with 5.3. One had cable and one had throttle by wire. The throttle body looked the same except the suburban had the throttle control motor bolted on the side. Looked like it could be removed and replaced with the cable setup. Hope that helps. Mark
Mike,
Does the same apply to the 6.0 and 8.1? I don't want to downgrade the driveline to a 5.3L. I sometimes haul heavy stuff and will be building a car trailer (double axle) as soon as the weather clears, so I need some punch.
Tim
