Guest obediencedenied Posted January 9, 2005 Share Posted January 9, 2005 The topic is basicaly my question.... would it be possible to steal the turn switch system from a chevy(any car or truck) and mount it on the Z column... so i can jus buy the GM universal wiring kit.. so i can jus plug into it instead of having to wire it all up? Thank you Red Quote Link to comment Share on other sites More sharing options...
Mike C Posted January 9, 2005 Share Posted January 9, 2005 I think if you wanted to do something like this, the best way to go about it would be to replace the entire steering column with a street-rod column. Integrating the wiring with different styles of switches could be daunting. The turn signal assembly on a GM column is much more integral than the Nissan switchgear. Quote Link to comment Share on other sites More sharing options...
Jolane Posted January 9, 2005 Share Posted January 9, 2005 That is along the same lines that I was planning on doing, replacing the steering column with something else. I don't like the feel of the stock switches basically, and the wiring probably could get easier. I would also like to have tilt. I was thinking of using a new Maxima or similar assembly though. A street rod assembly should also work well, I just have not gotten to the point where I have to choose yet. I do want something that looks 'right' though, not all shiny and out of place in my interior. As for changing just the switches, and reusing the steering column, I would think that with a little creativity and fabrication, it should not be that hard...famous last words I guess... Joshua Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted January 10, 2005 Share Posted January 10, 2005 GRRRRRR, I lost a bid on a Mustang tilt column. It looked like it would be perfect for a replacement. Oh well, gotta keep searching. Quote Link to comment Share on other sites More sharing options...
Guest obediencedenied Posted January 10, 2005 Share Posted January 10, 2005 Yea.. I like the idea that i will know that i did the wiring... but if i could use that GM switch assembly... then i could buy that GM harness.... thats what i wanted to go for. Doesnt seem like it would be that hard.. guess i dont know too much. Thanks yall. Quote Link to comment Share on other sites More sharing options...
Psykovertible Posted January 11, 2005 Share Posted January 11, 2005 I would use a tilt column out of a Jeep Wrangler. The ones from about 90 to 95 I', sure would look decent because they are basic and have GM wiring. Easy for parts too. I love these columns and may use one myself. Should be cheap to at a bone yard. They have auto tranny columns if needed but the shift indicator is built in I think Quote Link to comment Share on other sites More sharing options...
