75280z Posted January 11, 2005 Share Posted January 11, 2005 Ok i have searched and it looks like the Ultra flow has much better flowing capabilities then the super-turbo, i gess the main question i am asking is.. I am building a turbo engine and was just wondering which would be better for my application.. I am starting with a very small hopefully 200hp then building slowly I will upgrade i am going to run a 2.5 exhaust.. I am not building the worlds fastest car, just a quick one..I think that is all the info you guys will need.... also is it better to get an oval or circle muffler.. I hope i was clear enough thank you for your help. Quote Link to comment Share on other sites More sharing options...
Clifton Posted January 11, 2005 Share Posted January 11, 2005 If it's going to have a turbo I would only use a straight through muffler like the Ultraflo. Any back pressure after the turbo just slows it's spooling. I would also use 3", there is no drawback to going larger with a turbo and you won't have any regrets later. Quote Link to comment Share on other sites More sharing options...
HB280ZT Posted January 17, 2005 Share Posted January 17, 2005 I would also recommend the UltraFlo with a 3" mandrel bent exhaust system. I finished mine about 3 weeks ago, 3†dp with 3†mandrel bent pipe, Dynomax UltraFlo Welded (17221) and it sounds great. Most definitely does not sound like your average rice rocket!! No fart machine here!!! I have noticed a decrease in spool up time and it just plan runs a lot better now then it did on the old somewhat stock system (factor dp with a 2.5†crush bent system). Best of luch with whatever you decide. HB280ZT Quote Link to comment Share on other sites More sharing options...
