Can a 240Z with a single 3.5" exhaust be made quiet?
why dont you just run a nice quiet built nice size exhaust with a few quiet mufflers.. sorta like this http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=191815&prmenbr=361 maybe not that model but you get the idea.
and when you want to get up and go and use all your power, put in a electric cutout and open it up when you need it.
mike
Well I am using 1 supra TT MKIV muffler but i think it may have some bp...
Plumb in a pressure gauge just before the muffler with some copper tubing.
1 psi of back pressure is considered non-restrictive
2-4 psi is still good and will not make much difference on a street car.
5+ psi is costing you HP
All those pressures are measured at WOT, so testing gets a bit tricky, but maybe a track day would help.....
Guest Andrew240z
When Hot Rod did a buildup of a supercharged 240 back in the mid '80's they used mufflers out of a '72 Buick Riviera. Grandma had one of those, and it was a pretty quiet car, even with a 454 cid engine.
I'm guessing you meant Buick 455? ;)
