teamz Posted March 1, 2005 Share Posted March 1, 2005 I need to rebuild an R200 for a swap into a 73 240 with a R180. I have the factory manual for the 73. Does anyone know if the rebuild procedure and setup is the same on a R180 and a R200? Quote Link to comment Share on other sites More sharing options...
zcarnut Posted March 1, 2005 Share Posted March 1, 2005 The R200 has a different method of adjusting the pre-load on the side bearings than the R180. In addition the torque values are different between the differential fasteners as are the part numbers for all the various adjusting shims. Get the _correct_ FSM. Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted March 1, 2005 Share Posted March 1, 2005 Check here: http://carfiche.com/manuals/ for the 84 Z31 manual to download. That should help you out, information-wise. Doug Quote Link to comment Share on other sites More sharing options...
Guest 3154tm Posted March 2, 2005 Share Posted March 2, 2005 the on line service manual at this site has a good section on both the r200 and r230 http://300zx-twinturbo.com/ Quote Link to comment Share on other sites More sharing options...
