Big Block Z can it be done?
dsommer
Hmm..., that one's new to me, and I thought that I'd seen them all. :-)
On this site, Ron Jones, Ratsun and myself have BBC Z's. Another is currently under construction (can't recall the member's name). Another BBC (blue, used to have a blower) has since been converted to SBC.
Guest bastaad525
I saw a Z local here in the valley/SoCal that had a 400+ cube engine in it. It got my attention when I noticed the heavy duty chain chaining the block to the fender well... to keep the engine from ripping the engine mounts out :) They guy was claiming 600hp...
But why do it when 500 hp and 500 ft lb small blocks are very easy to build now-a-days.
Then add a 300 shot of N20 and push the hp to 800 hp which is more hp than you could ever use in a Z.
Big block are slow revers, very heavy, very wide, suck unbelievable amounts of fuel, and are better suited for heavier cars. I know because I have one of those pigs in my truck.
What we really need is more LS1 installations!
Forget that stoneaged BBC unless it is in a 4000 lb car with a huge gas tank.
Pyro,
There are two good reasons for doing a BBC swap:
1. You happen to have a long personal history with BBC’s, know them well, and can build them well.
2. You really really really like low-end torque. That 500hp/500 ft-lb SBC won’t have the low-end torque unless it also has the displacement – which IS admittedly possible today, but a 454 SBC will cost MUCH more than a 454 BBC.
My longstanding goal has been to build a car that pulls like a locomotive in the 600-2000 rpm range. Can I get that with a LS1 without power-adders?
The BBC is heavier and it is wider, but aluminum heads definitely help. As does aft firewall relocation. I’ll be the first to admit that a BBC hybridZ is a difficult undertaking and for most circumstances a poor allocation of effort. But not for all circumstances!
Granted, at “streetable†power levels the SBC makes more sense for most folks, unless reason #1 above applies. Certainly I have profound regrets about going BBC myself, but not because of the weight or installation issues – it’s because of the poor parts availability and high parts costs. The aftermarket – at least that portion that caters to amateurs – has largely foresworn big blocks. Increasingly, guys who build big blocks either do it for the muscle car nostalgia, or they’re pros racing 7-second drag cars. Neither description fits the “sportsman†drag racer.
However, if you don’t like turbos, nitrous or blowers, want to run low-octane gas and want on-demand torque even though you’re in the wrong gear, a BBC is hard to beat.
