Guest tony78_280z Posted March 22, 2005 Share Posted March 22, 2005 What tool would cut the cleanest and easiest when dealing with plastics? I'm preparing to slice up my center console to fit my Automatic shifter. I have the shifter lever, bracket, and the trim from the camaro it came out of. The black plastic kind of matches the Zs, and it has the P-R-O-D-2-1 that lights up when placed into gear. (Z was originaly a manual BTW) Getting it to fit sounds like quite a challenge and it doesn't need to be complicated with "How the hell am I gonna cut this?" In my arsenal of tools I have many cutting implements, but none that cut plastic too well. I have a dremmil (melts plastic and gets gummed up), A powerful Hand grinder with metal cutting disk (same as dremmil just faster and quicker at melting plastic and getting cummed up), a sawzaw (clumsy, ackward and I'm afraid it'll break the console before it cuts it), a rusty broken hack saw (broken), asortment of metal files (slow and gumms up), box cutter and a dull knife (r-rriight) 2+2 center consoles are rare. I don't wanna damage it beyond my current project. Quote Link to comment Share on other sites More sharing options...
Jolane Posted March 22, 2005 Share Posted March 22, 2005 Tony, I would recommend either an unbroken sharp hack saw or a jig saw (from the bottom side). A jig saw shouldn't cost much, and would probably be my first choice. Just go slow and be patient... Joshua Quote Link to comment Share on other sites More sharing options...
tannji Posted March 22, 2005 Share Posted March 22, 2005 there might be some cuts you couldnt manage with it, but a abrasive-coated wire saw would be the best.... with a close second to an open-ended hacksaw with a fine metal blade on it, for the cuts that you cant use a 2-pole saw like the hacksaw or wire saw on. Quote Link to comment Share on other sites More sharing options...
Rival5 Posted March 22, 2005 Share Posted March 22, 2005 i'd use a coping saw or like tannji said a wire saw. Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted March 22, 2005 Share Posted March 22, 2005 With a proper bit, your Dremel tool will work great! Used it for plastics many, many times. With the wrong bit, it melts the plastic and the bit gets "gummed up". !M! Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted March 22, 2005 Share Posted March 22, 2005 I was gonna say Dremel + miniature circular saw or like said above, wire saw. But since you tony helped solve the carb problem on my 240Z, I'll lend you my laser Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted March 22, 2005 Share Posted March 22, 2005 First thing is to take your time and lay out all your cuts. If you want alot of control (READ SLOW AND ACCURATE) use a snub hacksaw grip and a new blade. This hack saw only holds on to one end of the blade so you can get into tough spots. Take your time and you shouldn't have too much trouble. Dremel with the right cutter should work too but there is a bit more room for error if you don't have a steady hand. You can always cut inside the line and FILE the rest to fit. Just take you time... Quote Link to comment Share on other sites More sharing options...
Guest zNuclearBeast Posted March 25, 2005 Share Posted March 25, 2005 Hi all. Just joined this forum. This would be my first post. thought I would jump right in. All the suggestions thus far are great and will all work well, especialy all the advice on keeping it nice and slow. Didn't see this option so thought I would mention it. Consider using a "Spin Saw". Its a dremel like tool but with capability to have much higher RPM for finer cuts (most brands have variable speeds). Thge tool comes with drill bits that can cut sideways as well. So basicaly one would make the initial hole asomewhat inside the final intended finish line. Lock the tool at a suitable RPM and then simply follow the intended pattern. Care must be given to keep the tool perpendicular to the working surface as the bit can potentialy break if subjected to extreme angles and/or pushed too hard through the material being cut. Although very easy to use. I have a fairly shaky hand yet I have managed to cut decent straight lines with it. Probably under a $100 if you want to buy one or maybe rent it. Quote Link to comment Share on other sites More sharing options...
