savageskaterkid Posted April 7, 2005 Share Posted April 7, 2005 Wht does it take to make my Z capable of working with a manual Tranny. Its a 3-speed automatic, in an 81 280ZX. Theres a catch with this swap though, my car came with a manual, but the PO switched it out for an Auto, wht would the diffrences in this swap b? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted April 7, 2005 Share Posted April 7, 2005 clutch pedal and ,master and slave and tubing....that should be about it.... Plus flywheel and clutch obviously Quote Link to comment Share on other sites More sharing options...
Jolane Posted April 7, 2005 Share Posted April 7, 2005 And a manual tranny, shifter, manual console. Is the driveshaft the same length? Spline count? Tranny mount? Joshua Quote Link to comment Share on other sites More sharing options...
savageskaterkid Posted April 8, 2005 Author Share Posted April 8, 2005 yah, my automatic tranny is on its way out of the car any day now, i can feel the thing acting up, same with the engine-and i think im gonna convert it to a 5 speed. Will it b any easier to do this then the average Auto-manual swap, or will it b the same? Quote Link to comment Share on other sites More sharing options...
fl327 Posted April 8, 2005 Share Posted April 8, 2005 just helped a friend convert car to stick. pretty easy. you need a pedal, the master cylinder (firewall is already setup to take one, just remove the blockoff plate), the hardline to the slave cylinder, the slave cylinder and a rubber line which should come with a junkyard hardline, the transmission (duh), shifter, and thats about it. Auto driveshaft works for this as well, same splines and close enough lengthwise. We managed this conversion without taking off the dash to install the pedal, and so far, so good. Had to trim about 1" off the hole in the center console, it would hit trying to shift 1-3 and 5. Remember not to drop or lose any of those e clips... Quote Link to comment Share on other sites More sharing options...
