My Crank Trigger, Belt Driven, Toyota Supra Distributor (NO 56K)
Guest iskone
Guest iskone
Ok, I said a long time ago I'd pull it apart and get some pics.
I didn't have the tools to pull out the dist. drive shaft so that will have to wait. I'll get some measurements of the brackets and such, I use a 26" long XL belt to drive it. The cap/rotor is a Toyota Supra unit circa 1986
Wheres my altanator? It's on the other side flipped upside down of course. Where did you think it would be??? Take a look at my header thread to see the alt.
NO. I did not build it.
NO. It is not my design.
NO. It is not something you need. ****, It's not something I need but I'm keeping it :twisted:
Mounting
Timing wheel, belt and crank pulley
Tensioner and crank pulley
Crank Pulley
Removed
Rear veiw of bracketry
Side view (this is how it looks when on the engine looking down)
Plug wires had to be changed.
Bottom side of timing wheel
Rotor, time for a change
Rotor has to be tapped when changed to acomadate mounting screw
Optical pickup, I think
Iskone
