REV Limiter?
evildky
So my car is running great thansk to moby's updated maps and my DSM injector swap, I will be autocrossing it with MSnS for the first time sunday, I wanted to set a rev limiter to keep me from reaching too far headed for the corners I found one section for retarding the timing at a certain RPM is there a way of just stopping the ignitiion at taht rpm? anyone running a limiter? how did you go about it what kind of setts if you did the retard thuing how far did you retard it ?
Yes, the stock MSS code allows a "soft limiter" to retard the spark to a user configurable figure (mine is set to 5 degrees BTDC) for a user configurable number of seconds (mine is set to 2) at a user configurable RPM (mine is set to 6800rpm) with a "reset time".
On the same screen, the "hard limiter" is a fuel cut, that shuts off fuel at a user configurable rpm (mine is 7100), with the same parameters configurable as above!
