someone please check my injector wiring
ihatejoefitz
this is how i wired my injectors
injector 12V -> splice -> resistor -> injector1
...........................|-> resistor -> injector2
injector 12V -> splice -> resistor -> injector3
...........................|-> resistor -> injector4
injector 12V -> splice -> resistor -> injector5
...........................|-> resistor -> injector6
the other side of the injector i wired injctor 1 to the odd numbered injectors and injector 2 to the even.
sound okay? thanks for the help.
I will go with Jkube on that one let me try this:
12V+ ----- Resistor Pack-----Inj1+ Inj1(-)-----
12V+ ----- Resistor Pack -----Inj2+ Inj2(-)-----SPLICE -----INJ1(Gnd for Injectors thru MS)
12V+ ----- Resistor Pack-----Inj3+ Inj3(-)-----/
12V+ ----- Resistor Pack -----Inj4+ Inj4(-)-----
12V+ ----- Resistor Pack -----Inj5+ Inj5(-)-----SPLICE -----INJ2(Gnd for Injectors thru MS)
12V+ ----- Resistor Pack -----Inj6+ Inj6(-)-----/
Basically I have one common 12V+ lead to the resistor package, a stock unit from an 81N/A ZX, and then the grouping of the leads for the ground through the MS is what is important.
You can run this setup in either simultaneous, or alternating. I found better results while idling using alternatings two squirts per cycle...
The way you have it wired (if I understand what is there) will not have correct resistance, and is running injectors in series, which is not the way you should do it from what I understand.
I hope this looks better now that I edited it! LOL
I wired mine with the evens and odds it runs great no issues at all,
and it sounds like he has 4 injectors powered on one fuse circuit and 2 on the other, I fed 3 off each of the 2 circuits ,
each of the two 12v circuits has 2 lugs I used only one lug from each circuit to power the injecors
green block = relay board
orange = "inj 1"
yellow = "inj 2"
grey block = resistors
black block = injectors
red = "inj 12v"
so you guys are saying that the yellow wires need to go to injectors 123 and the orange wires need to go to injectors 456?
yes thats the popular way to run it, I however hast he orange/yellow wires run as in your schematic with no priblems at all, in a batch fire the 2 banks don't seem to really ba any better than one batch? and I'd seperate your power to 3 on each of the 12 circuits you have 2 on 1 and 4 on the other
