Remove radiator crossmember, relocate to here?
Ya I was grinding the other ones, cutting as much as I could with a chop saw then using a cut off blade on the die gringer to cut the rest..
With my new air die grinder I have much smaller wheels and it looks like it should cut much nicer, just waiting on a new compressor (took the 2hp 4gal back for a 6hp 27gal that I'll pickup soon).
The bandsaw seems to do a very clean job and has a much tigher turning radius, even with 3" cutting blades on my air die grinder, grinding just seems to heat the metal up and not always yeild nice level clean cuts as the bandsaw seems to, I just like to blaze threw it so thats probably half the reason for poorer results.
The end result is the same, brackets look like brackets, just trying to make it easier to cut 10 of em :)
  • Replies 40
