Guest newb81280zx Posted May 2, 2005 Share Posted May 2, 2005 I've been into cars a few years now and am now starting to learn more about american cars. I've been searching and am still confused about the difference between a big block and small block engine. I thought a long block was a full engine and a short block was just the block... but I am confused on this also. Also can anyone give me the basics on a stroker engine? I didn't want to have to ask this, but its better than being clueless forever. Thanks. Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted May 2, 2005 Share Posted May 2, 2005 I'll get you started..... 3.1L stroker engine link..... http://www.geocities.com/row4navy/engine.html Short block fundamentals link...... http://www.auto-ware.com/combust_bytes/shortblock.htm LARRY Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted May 3, 2005 Share Posted May 3, 2005 A short block is usually just the block fitted with the crank, pistons, and rods. A long block adds to that cylinder heads, timing chain, and timing cover and sometimes an oil pan. "Small blocks" generally refer to the smaller V8 sizes, typically between 305-400ci" (some aftermarket companies produce "small blocks" that go over 400ci, however, as a general rule, Chevy has not produced many 400+ci small blocks. Generally, all small block engine exterior components are interchangeable and some interior components are interchangeable. Big blocks generally range from 454ci-502ci. For all intensive purposes, most people begin with a small block 350ci. There is no big block 350 that I know of. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted May 3, 2005 Share Posted May 3, 2005 Ford made a big block 351. They used it in trucks. Quote Link to comment Share on other sites More sharing options...
boodlefoof Posted May 3, 2005 Share Posted May 3, 2005 big block and small block are completely different. No parts are interchangeable. The physical dimensions of the blocks are simply different. Chevy used to make the 348 "W" engine, which was a "big block..." Stroking is simply chaning the crankshaft stroke of an engine to increase displacement. A very popular "stroker" is swapping out a 3.48'' crank in a standard Chevy 350 small block and replacing it with a 3.75'' crank to make a 377 cubic inch (383 inches if you also do a .030'' overbore) engine. As above, short block has no cylinder heads, long block has cylinder heads. These are just various levels of completion of either a big block or a small block engine which you would purchase. Quote Link to comment Share on other sites More sharing options...
Guest newb81280zx Posted May 3, 2005 Share Posted May 3, 2005 This is very helpful. This all makes sense I think a lot of people just randomly say big block/ small block, which gets confusing. Thanks guys Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted May 4, 2005 Share Posted May 4, 2005 BIG BLOCK SMALL BLOCK they are two totally differant designs, big block chevy FACTORY PRODUCED sizes from 366-572 are available, weight tends to run about 100-150 lbs more than a small block and the basic engine is about 2" taller.2"wider and 2"longer than a small block small blocks chevy FACTORY PRODUCED sizes from 266-400 are available http://www.performanceunlimited.com/documents/engineweights.html http://www.performanceunlimited.com/documents/enginedimensions.html short block 4- bolt main block with 1-piece rear main seal, 5.700" P/M rods, and nodular iron crankshaft. Fully assembled - less cam, lifters and timing set,, oil pan,damper,flywheel, heads,intake, timing cover, water pump. long block in addition to short block a long block normally includes heads,cam,valvetrain,timing cover, and oil pan. still missing is a waterpump,damper,flywheel,intake, carb,distributor,exhaust manifolds, ETC. deluxe crate engine,("TURN KEY") complete DELUXE crate engines normally include most of the missing parts Quote Link to comment Share on other sites More sharing options...
