sims76 Posted May 17, 2005 Share Posted May 17, 2005 I'm leaking a little fluid out of my transmission where the driveshaft mates with the transmission. This has been keeping up the past few days since I changed the clutch. It is not coming from the speedo cable. I still have the shift boot out and can see it collecting there. Are there any serivceable seals on that end of the trans that I should have paid attention to? I put in the reccomended 1.6L of fluid, but didn't drain it using the drain plug, because I just let it drain out of the end of the trans until the fluid stopped coming out. If I now have 1.6L plus possible extra fluid in there, would this cause the leaking I'm experiencing? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 17, 2005 Share Posted May 17, 2005 Tail shaft seal is the likely culprit if it's not coming from the speedo. It's the seal that seals to the end of the driveshaft. Quote Link to comment Share on other sites More sharing options...
sims76 Posted May 17, 2005 Author Share Posted May 17, 2005 Thanks jmortensen, I didn't even know they existed. My Chevy buddy was surprised that I didn't replace that (referring to his GM transmission) and I was confused because I never read that about the nissan trans, but now I know. Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted May 17, 2005 Share Posted May 17, 2005 Also look at the seal contact area of the driveshaft slip-joint. If there is a groove at this location a new seal may not help. You'd have two basic choices at that point. Try to find a two-lip seal (I'm assuming the original is only single lip variety) that will place a seal lip in an unworn area or speedi-sleeve the slip-joint in the seal contact area. I've used these on many applications with great results. A speedi-sleeve is a very thin stainless steel ring of varying diameters and widths used to repair the seal surface area on balancers, yokes, etc. when excess wear prevents proper oil seal operation. Do a search on the web. Quote Link to comment Share on other sites More sharing options...
