blairjj Posted May 18, 2005 Share Posted May 18, 2005 I recently purchased an 83 ZXT basket case for the drivetrain for my 71 240z. When I pulled the transmission drain plug to drain the ATF I instead got heavyweight gear oil out. I've read the Haynes and BW manuals and they are very specific about NOT using gear oil. So... much question now is what is the best way to get all of the gear oil out of all of the passages in the T5? Am I looking at a complete rebuild here? Thanks in advance. Jay Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted May 18, 2005 Share Posted May 18, 2005 If I were you I'd forget the ATF and run over to my local Chyrsler or Chevy dealer. Once there, pick up as many quarts as needed of the Castrol synthetic used in the NV4500 5-speed gearboxes found in the one-ton trucks. This stuff is awesome although quite expensive (around $20 a quart). You won't need to worry about opening up your tranny because what little gear lube remains will blend with the Castrol product. Shifting will be butter smooth (assuming the box is in good condition) all year around. Quote Link to comment Share on other sites More sharing options...
Mike C Posted May 21, 2005 Share Posted May 21, 2005 Until '85 on the Mustang, and '88 on the Camaro as well as the Nissan boxes and jeeps, the T5 used gear oil. Only the WC boxes run on ATF. Quote Link to comment Share on other sites More sharing options...
spork Posted May 21, 2005 Share Posted May 21, 2005 yup, I run 75-90w sythetic mobile one in mine...our trannys used the gear oil, not atf... Quote Link to comment Share on other sites More sharing options...
blairjj Posted May 22, 2005 Author Share Posted May 22, 2005 Whew.. Glad to hear that! Thanks guys! Jay Quote Link to comment Share on other sites More sharing options...
