woldson Posted May 21, 2005 Share Posted May 21, 2005 i just found out that my 83280zx dose have dwell it can not be ajusted though. can i do spark conrtol with this and ms? Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 21, 2005 Share Posted May 21, 2005 I am at a loss as to what you are asking, or what significance "dwell" has on anything being questioned. This is the same question you asked earlier, and the answer is still the same as it was then: MSS will run your car, and if you want to control coil packs use MS-n-EDIS. What/why/how does "dwell" come into the conversation at all. Am I missing something? With WHAT, and MS? Quote Link to comment Share on other sites More sharing options...
woldson Posted May 21, 2005 Author Share Posted May 21, 2005 sorry, to do spark contorl with the ms useing distrubtor with the car and not go to the gm modual since my dis has dwell....is that better? Quote Link to comment Share on other sites More sharing options...
woldson Posted May 21, 2005 Author Share Posted May 21, 2005 i want to go to turbo later, my friend has a porche turbo 86 911 and lots of pipeng he will let me have for cheap. so ihve been tring to find out if my distrubutor will work under this senerio. Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 22, 2005 Share Posted May 22, 2005 You have an 82 Normally Aspirated 280ZX? Then the same thing that was in the first post (mario answered it!) where you asked the question STILL is applicable: YES, MS will run the car. The distributor is a distributor and not a Crank Angle sensor, or a gutted unit like in the 81 turbos. The only people recommended to simply make the MSS conversion are those people with TURBO 280ZX's. Not those with a NORMALLY ASPIRATED that they are planning on converting. Please let people have ALL the information AT ONCE and you will get beter answers, and it will not be like pulling teeth for either one of us. Also searching and reading is a good idea, as the MSEFI site would have answered this question in a quite straightforward manner. You simply hook your MS "tach" input to your coil negative terminal, and run it fuel only. This is the BASIC MS system. I'm still not understanding something here, exactly why are you fixed on controlling spark, again? In an N/A? if you are going to control spark, you will need the GM Module for the interface because the Megasquirt does not have dwell, and the Megasquirt is what will be controlling the spark if you set it up that way. But I am giving up, this seems to be a lack of reading or research thusfar. Quote Link to comment Share on other sites More sharing options...
woldson Posted May 22, 2005 Author Share Posted May 22, 2005 hey i sorry, my turbo rebuild may come sooner than i thought, and i was makeing inquires in the stock inginition side, wondering if ms will work with it for spark and dweell with a turbo. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted May 22, 2005 Share Posted May 22, 2005 MSnS_extra code will control spark and control dwell, but that code requires a little more research up front than regalur MSnS. It has a lot more settings and potential for mistakes because it gives you a lot more things to control. Do everyhting a step at a time. So setup fuel only, then when it works good move on to spark. A gm module is only $13 so maybe set up with GM module for a couple days and when it works good then try using dwell control and stock module(removing GM module from the setup). Once you jump in and do the fuel only setup you will learn a lot more about megasquirt in general. Quote Link to comment Share on other sites More sharing options...
woldson Posted May 23, 2005 Author Share Posted May 23, 2005 thankyou that is exzacty what i ll do. i know i will have to learn it so starting off easier so excellent! thanks again good advice Quote Link to comment Share on other sites More sharing options...
