Administrators SuperDan Posted May 28, 2005 Administrators Share Posted May 28, 2005 Sezied @#$%& pieces of $%&*@! %@#&! #@^% !@)$_$@. ##@& cutting torch and the T^&!!^# #@^&*!!!!!!! Quote Link to comment Share on other sites More sharing options...
johnc Posted May 28, 2005 Share Posted May 28, 2005 Keeping soaking it with penetrant (3M, Kriol, etc.) Try drilling a hole in the bottom of the strut tube and soak it from there. Expect to soak it for a week or two. Then, using a big pin punch, try punching the shock out of the strut from the bottom through the hole you drilled. An Air Hammer with a long pin also works miracles. If that doesn't work, heat the strut tube with a torch and then try punching it out from the bottom. And, if all of that fails, you can bring it to my shop and I promise I'll get them out! Quote Link to comment Share on other sites More sharing options...
Jeff Posted May 28, 2005 Share Posted May 28, 2005 Ooooh, Ooooh I know hook it between two trucks and try to yank it apart! Oh wait that's already been tried, sorry Mat. Obscure thread reference here. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted May 28, 2005 Share Posted May 28, 2005 Come on, Dan....Man Up dude! Quote Link to comment Share on other sites More sharing options...
Vintage-TechZ Posted May 28, 2005 Share Posted May 28, 2005 Dan The last time I had to deal with this I soaked the whole assembly in a tall 7-gallon plastic pail filled with Muratic acid and tap water for the afternoon. Makes a great soup ! If the Cartridge has bad corrosion...it should bubble and boil it right the hell out. It worked killer for me. Just remember to handle it with rubber gloves and safety glasses and then wash it REAL good a few times with a strong soap to neutralize the acid. Hope this helps........don't forget to use a Rose Bud torch to aid just before you pull ! Vinny 8) Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted May 28, 2005 Share Posted May 28, 2005 Quote Ooooh, Ooooh I know hook it between two trucks and try to yank it apart! Oh wait that's already been tried, sorry Mat. Obscure thread reference here. Haha! I still chuckle thinking about that. I lost those pictures from that thread when I got a new computer. !M! Quote Link to comment Share on other sites More sharing options...
jt1 Posted May 28, 2005 Share Posted May 28, 2005 I think removing a rusted strut is a rite of passage for Z owners. Mat needs to post up the pic of the truck again, that was a classic!!!!!!!! John Quote Link to comment Share on other sites More sharing options...
Administrators SuperDan Posted May 28, 2005 Author Administrators Share Posted May 28, 2005 Got 1 $%##@ out, but the other &@#$! %#&@! is one stuck !@)$#&@!!! Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted May 28, 2005 Share Posted May 28, 2005 Quote Got 1 $%##@ out, but the other &@#$! %#&@! is one stuck !@)$[/email']#&@!!! Dude, watch your language! The moderators around here are anal about that kind of talk. Don't want to get banned, do you? Quote Link to comment Share on other sites More sharing options...
Administrators SuperDan Posted May 28, 2005 Author Administrators Share Posted May 28, 2005 Quote Then, using a big pin punch, try punching the shock out of the strut from the bottom through the hole you drilled. An Air Hammer with a long pin also works miracles. Ok, all is right in the world again. Air hammer is the key BTW. Quote Come on, Dan....Man Up dude! Thanks again for your help Tim Quote Link to comment Share on other sites More sharing options...
Tim240z Posted May 28, 2005 Share Posted May 28, 2005 Quote Thanks again for your help Tim Pleasure is all mine Quote Link to comment Share on other sites More sharing options...
