Rear 240sx Rebuild
There is an o-ring that should be replaced in the piston. Disassembly is fairly straightforward. You should get the o-ring seal you need in the re-build kit.
Also, there’s actually a tiny air vent hole at the end of the piston that usually clogs up with dirt that needs to be inspected. Clean it out with a welding tip file if necessary.
