SR20DET Smogable?
my friend got referreed (sp?) for exhaust on his S14 with a s14 sr20 motor and made him do a full smog and he didnt even get hassled at a ref station, he also had full blitz fmic, its possible, just depends who you get.
i have a calif smog license.if a ref station passed a car with a jdm engine the guy was real lucky.but once it gets the door frame sticker issued at the ref station its a done deal.you are only supposed to use a same year or newer engine from a cali vehicle .no cali cars had jdm engines.alot of jdm engines dont use egr-that is the giveaway.if the car came to me for a smog test and it had ref swap sticker in the door frame i would smog it as long as everything was hooked up correctly and stuff like egr and tank evap system are functioning.but it would get a very thorough going over.stupid things like k&n breather filters on the valve cover(modified pcv system)or timimg out of spec would get it failed.some of the techs that come out of a certain auto trade school in the bay area arent too bright.i managed a shop in hayward before i had a smog license.there were 2 shops down the street that worked on old rolls royce and lotus.i would have to set the carbs up for the smog tech.he had never seen a weber or su carb.
Even though there are probably a few examples of people sneaking one by, its not a legal swap. The SR20DET was never certified by the EPA/DOT in any US chassis so the engine is not allowed in any vehicle operated on a US highway.
Now, if you took a SR20DE and turbocharged it, you would have a better chance of getting it passed because the SR20DE was certified. If you can make that case to a referee (not just a smog tech) with your JDM SR20DET then maybe you can get the car through the smog system.
