FEnatic Posted June 6, 2005 Share Posted June 6, 2005 Tried the search, just want to know how much I can take off of a N47 head without worrying about shimming? I was thinking no more than .010. Also, what is the color of the stock engine block? Is there a commercially available spray? Last, What is your ideas on Cam spray bars, good or not required? Thanks Quote Link to comment Share on other sites More sharing options...
datsunlover Posted June 6, 2005 Share Posted June 6, 2005 No idea on the stock block color.. As for the head.. I think you could probly take .015-.020 off and not have to worry about shiming the cam towers, although if you're gona run a bgiger (than stock) cam, you'll have to do the math and get the right lash pads.. Bant valves suck. On the spray bar; there was a post I made a while back about this.. I guess it just depends on who you talk to about it, some say use it, some say not. Personaly, I'm running one and have had no problems. From what I understand, it's not a problem till you start neglecting oil changes, and then it can possibly get cloged, wich could cause a few problems with lubrication in the top end.. Quote Link to comment Share on other sites More sharing options...
Whittie Posted June 6, 2005 Share Posted June 6, 2005 stock block colour (well for the l28 anyways, dont know about any others, i presume it would be the same) is a blue. Tom. Quote Link to comment Share on other sites More sharing options...
