R200VLSD into R200
zolorin
Here in san diego there are very few R230 since cars don't die from rust so for the R230s to appear it will take some time. I did came across a R200VLSD (or I think it is) an Infinity with VG30de engine. The test that I did was spin one tire and observe the other and see if it rotates in the opposite direction, and if yes then it is open otherwise ask questions. So this one did not spin backwards which means that it could a VLSD.
So the first question is, is it an R200VLSD?
Second question is
I have R200-3.36 (they do exist and 37:11 is a proof enough), I want to make it into the R200-3.36 VLSD. Is it possible to use the guts of the VLSD and stuff it into the desired ring and pinion say from my desired R200?
What else do I need (halfshafts come to mind) etc.
Ring gear #'s "39:11" = 3.54........"37:10" = 3.70..... are you sure that you are not reading "37:10 on the large ring gear.. I am confused. 3.36 diffs exist but is the ring gear designation : 37.11[/u'] for a 3.36 diff.
37:11 does equate to 3.36.....37 divided by 11 = 3.3636364
