Re; 2 piece wheels
Hi guys,
What is the difference between 2 piece and 3 piece wheels. I know with the 3 piece wheel you can exchange the two shells (inner/outer) to get different widths. Can a 2 piece wheels have its shells interchange for different widths also?
Regards, Ari
I would suggest to contact the seller and get the manufacture name and check to see if they have a website.They normally would have the info your looking for, Otherwise as far as I know 2 pc wheels either have the outer wheel made with the center removeable to change the bolt pattern. But it really is dependent on the manufaturer. BBS makes 2 pc with the outer and the center in one piece and the change the inner rim half to changed the inside offset. But to make sure you should try to get the seller to get you that info.
