Guest TegRacer324 Posted June 28, 2005 Share Posted June 28, 2005 Well actually I guess I have two. I've been looking into fuel cells since I pretty much figured out it'd be easier to mount that than the old tank and I've seen the threads on here about them. Are the Fuelsafe/ATL cells worth the extra money? And actually the question I'm really wondering is I've seen that you can get them with metal cases surrounding them and ATL said something about building the box. Is that required in installing the tank? Is it just soft rubber that you get from the factory? Quote Link to comment Share on other sites More sharing options...
johnc Posted June 28, 2005 Share Posted June 28, 2005 I posted at length about this in one of the fuel cell threads. People confuse the "fuel cell" with the box its mounted in. An ATL or Fuel Safe fuel cell is a Kevlar/Nylon bag that contains anti-vapor foam blocks and has an aluminum fill plate on top. That bag then gets placed inside a sheet steel or sheet aluminum box. The box then gets mounted to the vehicle in some way. Other types of fuel cells (mostly drag race) are made like a regular fuel tank with a blow molded plastic "bag" containing anti-vapor foam and provisions for filling. That plastic bag also acts as the "box" that's strap mounted to the vehicle. ATL and Fuel Safe fuel cells meet all racing sanctioning body safety requirements and meet all FAA fuel cell safety requirements. IMHO they are the only fuel cell you should be installing in your car if you plan to take it on a race track. For a street car, the stock tank or any of the plastic tank ones (Summit, Camaro LS1, etc.) are fine. Quote Link to comment Share on other sites More sharing options...
Guest TegRacer324 Posted June 29, 2005 Share Posted June 29, 2005 Thanks for the answer. Yeah I think I saw that post in one of the threads, but I was a bit confused by it I guess. Just wanted to make sure it was what I thought. Quote Link to comment Share on other sites More sharing options...
clarkspeed Posted July 1, 2005 Share Posted July 1, 2005 I concur with John's comments. Having used both, I lean toward the ATL as my favorite. Quote Link to comment Share on other sites More sharing options...
