mom'sZ Posted July 12, 2005 Share Posted July 12, 2005 Please folks, I spent hours using the search function last night reading unrelated posts, so please don't tell me to just search. I need a set of stock fuel injectors. I want new, not rebuilt. MSA sells them for about sixty buck a piece. Does anybody know of somewhere cheaper or is this a pretty good deal? Also, related subject: for anyone familiar with SCCA Improved Touring rules and common practices, must the fuel injectors be stock fuel flow rating or may an otherwise identical replacement injector with a higher flow rating be substituted? Thanks everyone Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted July 12, 2005 Share Posted July 12, 2005 Please folks' date=' I spent hours using the search function last night reading unrelated posts, so please don't tell me to just search. I need a set of stock fuel injectors. I want new, not rebuilt. MSA sells them for about sixty buck a piece. Does anybody know of somewhere cheaper or is this a pretty good deal? Also, related subject: for anyone familiar with SCCA Improved Touring rules and common practices, must the fuel injectors be stock fuel flow rating or may an otherwise identical replacement injector with a higher flow rating be substituted? Thanks everyone[/quote']Sixty for new is not a bad deal. You will want to stick with stock flow, and even if higher flows are allowed in the rules, you will not make more power unless you improve the airflow. And even then, for minor changes in airflow, the stock injectors are able to fuel your engine properly; richer will only go slower. Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted August 3, 2005 Author Share Posted August 3, 2005 Hi group I've got the injectors and I also got some of those wire end thingies to replace the ends on the wiring harness. On the stock harness, both wires are black. Does it matter which wire goes to which side of the injector? Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted August 12, 2005 Share Posted August 12, 2005 I realize this may be late on the chime in, but i have 6 new injectors still in there boxes/plastic wrap if your interested, if the best quote you got was i'll do $50 per. Quote Link to comment Share on other sites More sharing options...
Thumper Posted August 12, 2005 Share Posted August 12, 2005 No it does not matter what wire goes where on the injector. Also it doesn't matter what injector cap goes on what injector since they all fire at once. Quote Link to comment Share on other sites More sharing options...
