kraymond Posted July 20, 2005 Share Posted July 20, 2005 http://www.car-part.com/ The 5.6 nissan is plentiful at the JYs and cheaper than an ls1. Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted July 20, 2005 Share Posted July 20, 2005 What car is it from? 5.6 liter engine, from Japan? really? Quote Link to comment Share on other sites More sharing options...
kraymond Posted July 20, 2005 Author Share Posted July 20, 2005 The 5.6 is from the Titan and Armada. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted July 20, 2005 Share Posted July 20, 2005 i havent seen a 5.6 from a titan or other nissan suv's at one junkyard yet. it hasnt been swapped in yet as far as i know but it would be a cool swap. wonder if the 350Z 6-speed bolts up to it?? mike Quote Link to comment Share on other sites More sharing options...
NZeder Posted July 20, 2005 Share Posted July 20, 2005 I assume whatever fits to the other Nissan VK engines with fit these as far as trans goes. Nissan VK56DE cool hybrid-Z Quote Link to comment Share on other sites More sharing options...
mtcookson Posted July 20, 2005 Share Posted July 20, 2005 as far as anyone is aware, there aren't any manual trannies that bolt right up to the VH/VK engines. one can be bolted onto the engine using a conversion plate or custom bell housing pretty easily. i wouldn't use a Z 6-speed though. they've been known for having some issues (the earlier Z33 6-speeds at least). the newer ones might be a bit more expensive. i'd use a Z32 5-speed personally. very strong tranny and can be had for very cheap. Quote Link to comment Share on other sites More sharing options...
karay240 Posted July 21, 2005 Share Posted July 21, 2005 I highly doubt that it'll bolt up, nor that it could handle the torque of the VK56. It would be a cool swap if you could mate a MT on it though. Quote Link to comment Share on other sites More sharing options...
mtcookson Posted July 21, 2005 Share Posted July 21, 2005 the z33 or z32 tranny? Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted July 21, 2005 Share Posted July 21, 2005 Interesting, is the 5.6 Nissan engine all aluminium or with iron block? Quote Link to comment Share on other sites More sharing options...
mtcookson Posted July 21, 2005 Share Posted July 21, 2005 should be all aluminum. the VH45DE is all aluminum. the VK45DE came from that engine and the 56 from that. most newer engines are all aluminum anyways so that'd be the safest bet. Quote Link to comment Share on other sites More sharing options...
crazy280 Posted July 24, 2005 Share Posted July 24, 2005 The Titan and Armada are practically brand-new, I would be surprised if their engines are "plentiful" in the junkyards.... edit: I guess if you search online you could have one shipped....not the same as dropping by the local JY though Quote Link to comment Share on other sites More sharing options...
ARGAMEMENON Posted July 24, 2005 Share Posted July 24, 2005 There's only 3 VK56's on car-part.com, ranging from $3,000 to 3,800. I've been wanting one bad to TT, but don't have that kind of cash right now, so a vh45 will have to do for the meantime. They weigh 228kg's (511), all aluminum, and nothing bolts right up. You could have an adapter plate or a bellhousing made up to fit any tranny as Cookson said, if you wanted it bad enough. Quote Link to comment Share on other sites More sharing options...
