spec stickers
Eric
how acurate are the spec tags under the hood and in the door jam? i know on my 200sx it's says it weighs around 3600 pounds, but they only weigh around 2500. and the hp rating, is it correct? sorry if it's already been asked, i couldn't find it.
The plate says GVWR doesn't it? Gross Vehicle Weight Rating. Its the maximum total weight of the car including all the stuff you can put inside. Its not the Net weight of the car.
With your example, the GVWR is 3600lbs, net weight is 2500lbs, therefore you can pack about 1100lbs of stuff into the car before you exceed the weight rating.
http://www.rvsafety.com/gvwrworksheet.htm
