60-1 horsepower ??????
240zprace
what kind of power can i expect from a 60-1 turbo w/ stage 5 exhaust wheel??
some specs:
3" dp and exhaust
15 lb. boost
web cam
fmic
sds efi
custome intake (like james thagards)
480cc injectors
i hope the injectors are enough to run 15 psi. the compressor map shows that the turbo should flow enough air for 450 hp @ 15psi. i hope i can make 300-350 rwhp @ 15psi... let me here your thoughts... can i or can't i???
At 15 psi........
255 hp @ 5000 rpm with stock cam and stock head,
300 hp @ 6000 rpm with MSA stage I turbo cam.
330 hp @ 6500 rpm with MSA stage II turbo cam.
rpms make a big difference in power output and a bigger cam is needed for that.
up it another 5% with a little head work. 270hp, 315hp, 345hp.
try this site to predict hp from a turbo: http://www.turbofast.com.au/tfcalc.html
