240zprace Posted August 9, 2005 Share Posted August 9, 2005 what kind of power can i expect from a 60-1 turbo w/ stage 5 exhaust wheel?? some specs: 3" dp and exhaust 15 lb. boost web cam fmic sds efi custome intake (like james thagards) 480cc injectors i hope the injectors are enough to run 15 psi. the compressor map shows that the turbo should flow enough air for 450 hp @ 15psi. i hope i can make 300-350 rwhp @ 15psi... let me here your thoughts... can i or can't i??? Quote Link to comment Share on other sites More sharing options...
akeizm Posted August 9, 2005 Share Posted August 9, 2005 The 480cc's will be fine. I'm running 440cc's and they will do the job past 300hp nicely. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted August 9, 2005 Share Posted August 9, 2005 You should get close to 300 rwhp, maybe over depending on the tune...at 15 psi. Quote Link to comment Share on other sites More sharing options...
Pyro Posted August 9, 2005 Share Posted August 9, 2005 At 15 psi........ 255 hp @ 5000 rpm with stock cam and stock head, 300 hp @ 6000 rpm with MSA stage I turbo cam. 330 hp @ 6500 rpm with MSA stage II turbo cam. rpms make a big difference in power output and a bigger cam is needed for that. up it another 5% with a little head work. 270hp, 315hp, 345hp. try this site to predict hp from a turbo: http://www.turbofast.com.au/tfcalc.html Quote Link to comment Share on other sites More sharing options...
EZ-E Posted August 9, 2005 Share Posted August 9, 2005 Well I will tell you this, I was amazed at what a 91 Civic hatchback with a 60-1 and a bit of work was running low 12's at the track consistently all night long. Quit an amazing lil car. Quote Link to comment Share on other sites More sharing options...
