afbrian13 Posted August 12, 2005 Share Posted August 12, 2005 I see that there are 2 main versions on the MS&S, the V2.2 and V3. What are most of you running and which is better(from ease of use and intial tuning standpoint)? Is map programming interchangeable between the two? I have my relay board on order but can't decide which version to go with. Any insite/personal experiance would be great. As always, thanks, Brian Quote Link to comment Share on other sites More sharing options...
Guest 81na ZX Posted August 15, 2005 Share Posted August 15, 2005 The version refers to board design, not software. V3.0 has alot of intergrated features, so it depends on if you want them. Alot do to spark, but if your running a dizzy'd L-series, the earlier board works fine. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted August 15, 2005 Share Posted August 15, 2005 I think at this point that almost everyone runs V2.2 hardware. The software changes all the time (MSnS_Extra) so who knows what versions everyone has. 021u is good 024s9 is good there are lots of newer ones Quote Link to comment Share on other sites More sharing options...
envmyz Posted August 15, 2005 Share Posted August 15, 2005 running 25i6 right now, seems to be working fine. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted August 15, 2005 Share Posted August 15, 2005 V3 board has driver for coil - don't need HEI module. or those of us wanting to do things in stages, can come back later and do EDIS. Also has FIDLE output. Also, has provision to support LowZ injectors - no flyback board needed. This what I am going to. Quote Link to comment Share on other sites More sharing options...
