Version to go with.....
afbrian13
I see that there are 2 main versions on the MS&S, the V2.2 and V3. What are most of you running and which is better(from ease of use and intial tuning standpoint)? Is map programming interchangeable between the two? I have my relay board on order but can't decide which version to go with. Any insite/personal experiance would be great.
As always, thanks,
Brian
Guest 81na ZX
The version refers to board design, not software. V3.0 has alot of intergrated features, so it depends on if you want them. Alot do to spark, but if your running a dizzy'd L-series, the earlier board works fine.
