turbo swap runs rich
tomz76
I finally finished my engine swap. yahooo!!!! I used an 82 motor/ECU and it it runs well but fowels(spelling) plugs. I used the intake manifold from my 76 (federal model). There is no EGR valve and obviously no factory BOV. I am using a cone filter inside the engine compartment and a KHS BOV. One part i did't use is a thing that plugs into the ECU, intake pipe, EGR valve, Factory BOV, and the intake manifold. Is this the MAP sensor? Also would not using this make my plugs go bad :) I have the adjustment screw on the AFM backed off almost all the way. I am at a loss.
Thanks for any help
Tom
