SR240Z Posted August 31, 2005 Share Posted August 31, 2005 the s13 turbo maxs out at 255whp and s14 turbo around 270whp, s15 t28 has been pushed to 320 whp but it was way out of efficiency. Quote Link to comment Share on other sites More sharing options...
Confused Posted August 31, 2005 Share Posted August 31, 2005 I said 250-270. Its an estimated guess. And as for what Alex said, he is correct. Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted August 31, 2005 Share Posted August 31, 2005 Yup 260 Was The Highest I've Seen On A S13 T25 Turbo But It Was Very Ineffcient. The S15 Would Be Best Suited For 300whp When Supporting Mods Are Added To Take Up Some Of The Work Load. Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted August 31, 2005 Author Share Posted August 31, 2005 The 6spd Has A Lower Final Gear Ratio Than The 5spd.... So Crusing Rpms Are Higher And Top Speed Is Lower With Thte 6spd. The Best Sr Engine Is The S13redtop For The Good Flowing Head.... Which Helps Create More Power When Upgrading.... But Essentially All The Sr's Are Good. Yup 260 Was The Highest I've Seen On A S13 T25 Turbo But It Was Very Ineffcient. The S15 Would Be Best Suited For 300whp When Supporting Mods Are Added To Take Up Some Of The Work Load. OK, S13 or S15. The S15 initially has more power. Apparently it will sustain more horsepower? Is there any reason to buy an S13? The cost is initially cheaper, and its head flows better at 500hp. Any other reason? Anyone? Does the S15 have any advantages? More initial horsepower, better turbo. Anything else? Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted August 31, 2005 Share Posted August 31, 2005 The Only Reason Why The S15 Has More Power Stock Is Because It Has A T28 Turbo Compaired To A T25 And It Runs 10psi Of Boost Compaired To 7psi. The Only Other Differences Between The S15 And S13 Is The S15 Comes With Vvtc, Different Style Of Oil Squirters (suuposedly More Effcient), 480cc Injectors Over 370cc, Special Maf Capable Of ~350whp, Differnt (internal Ignitor) Coils, And 6spd On The R-spec. Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted August 31, 2005 Share Posted August 31, 2005 It Sounds Like You Are Trying To Justify A Purchase And You Really Want A S15..... I Can Tell You Right Now..... If You Get A S15 Motor Assembly You Have To Modify The Transmission To Adapt A Speed Sensor Or Get The S15 Diff And Custom Build Half Shafts And Then Get A Abs Signal Convertor And Electric Speedo To Get A Speed Reading. Quote Link to comment Share on other sites More sharing options...
Confused Posted August 31, 2005 Share Posted August 31, 2005 The only difference besides power, is cost. For an S15 Blacktop, you would most likely be doubling the cost of an S13 Redtop. Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted August 31, 2005 Share Posted August 31, 2005 OK, S13 or S15. The S15 initially has more power. Apparently it will sustain more horsepower? Is there any reason to buy an S13? The cost is initially cheaper, and its head flows better at 500hp. Any other reason? Anyone? Does the S15 have any advantages? More initial horsepower, better turbo. Anything else? I MEANT THE S15 TURBO WOULD BE BEST SUITED FOR 300WHP WITH SUPPORTING MODS NOT THE ENGINE. BOTH THE S13 AND S15 ENGINES WOULD BE GOOD AT 300WHP BUT ONE WILL INHERENTLY COST SIGNIFICANTLY MORE TO GET THERE THAN THE OTHER. Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted August 31, 2005 Author Share Posted August 31, 2005 OK, I wasn't trying to be difficult. I am just new to the nissan 4 cylinders. I am just trying to build the best car I can on my budget. I just didn't know the differences. After input and research, I am going with an S13. I suppose if I can find a black top, I will get it since it will not be as old as the red top. Hopefully, it will have fewer miles. Does anyone know of a good source or are there any suppliers that can hook me up with a low mileage red or black top S13 for a good price shipped to 47401? Thanks. Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted August 31, 2005 Share Posted August 31, 2005 Its Good That You Are Asking Questions And Doing Proper Research Before You Get Started.... There Was Many A Time I Wish I Had Done More Asking/research Before I Started A Swap. The S13 Would Be The Easier Install With A Lower Initial Cost (which Means More Money To Put Towards Power). The S15 Is About Double The Cost Plus There Is Alot More Work Involved In Wiring, Speedo Installation, Etc. Good Luck In Whatever You Decide And If You Need Help Just Keep Asking... I'm Sure With The Collective Knowledge Here We Can Help You Figure It Out. Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted August 31, 2005 Share Posted August 31, 2005 As far as engine sources go, try: http://www.advantage-imports.com http://www.jarcoinc.com http://www.nippon-motors.com I've heard good things from each of these sources. Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted August 31, 2005 Share Posted August 31, 2005 Or Vildini Motorsports..... Quote Link to comment Share on other sites More sharing options...
Confused Posted August 31, 2005 Share Posted August 31, 2005 Or Vildini Motorsports..... :wrd: Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted August 31, 2005 Author Share Posted August 31, 2005 I sent an e-mail to Alex at Vildini. Since they actually participate here, I suspect that they will be the most likely to provide a reliable engine. Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted August 31, 2005 Share Posted August 31, 2005 Oh, I didn't know Vildini actally supplied engines too. I thought they were just a swap shop. By all means, check them out then! Quote Link to comment Share on other sites More sharing options...
SR240Z Posted August 31, 2005 Share Posted August 31, 2005 yea lewis, its $2000 for engine, tranny, ecu, harness, maf and ignitor and then $300 for the engine cradle mount. shipping i will find out tomorrow, would you need a liftgate at your place or do you have a business address with a forklift to take it off the freight truck? Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted September 1, 2005 Author Share Posted September 1, 2005 I will have it go straight to my mechanic. I don't think he has a forklift though. A liftgate will probably be necessary. Thanks. Oh, BTW, I asked questions about reliability of your engines and what steps you take to make sure that your engines are reliable. You did not answer those questions. Other companies do compression and leak down testing. Some do other things. I am just trying to make sure I get the best engine possible for my money. I would like to have a great swap. Thanks. Lewis. Quote Link to comment Share on other sites More sharing options...
SR240Z Posted September 1, 2005 Share Posted September 1, 2005 well we do the usual compression and leakdown test, if you want we can do a stock rebuild on one of the motors for an extra $1000 would include new stock oem headgasket, new piston rings, new rod bearings and new main bearings and it would be basically a new engine again. Quote Link to comment Share on other sites More sharing options...
Confused Posted September 1, 2005 Share Posted September 1, 2005 Not a bad price. And for a practically new engine, its all the better. Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted September 1, 2005 Share Posted September 1, 2005 jeez, most places you pay 2500 just for the engine/trans/computer/harness! 3k for all that stuff with the engine rebuilt? wow. Quote Link to comment Share on other sites More sharing options...
