oinojo Posted September 7, 2005 Share Posted September 7, 2005 sup guys, im in the verge of swapping my stock rebuilt l28et into my 240z and i was wondering what kind of gas milage you guys are getting. (daily driving - includes having fun with the throttle:)). Thanks for your time. -jon Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted September 8, 2005 Share Posted September 8, 2005 hey dude, well I already replied to your PM, but I'll reply here too, for future searchers looking for fuel mileage answers pretty much bone stock L28ET setup, running 12-14psi of boost depending on my mood, flooring the throttle at every opportunity, I get about 17mpg's. Driven 'normally' (only done once as an experminent thru one full tank to see how much difference it made), I got about 20mpg's. This is with approximately 1/3 street and 2/3 freeway driving. I'm at the low end of the spectrum though... my car runs pretty rich overall, even at idle and cruise, which hurts my mileage quite a bit. If everything were running 'right', I'd expect no less than mid 20's. Quote Link to comment Share on other sites More sharing options...
EZ-E Posted September 8, 2005 Share Posted September 8, 2005 In the ZX I have which is an 82, when it was still with stock injectors and turbo, running at 15 psi intercooled, usually netted about 18 in the city, and anytime during travel at approxiamately 75 on the highway I would get around 26-28mpg. I would think with a lighter car you should do quite well. Quote Link to comment Share on other sites More sharing options...
tonycharger72 Posted September 8, 2005 Share Posted September 8, 2005 How much you guys paying for fuel in the states, Its just hit about $1.40AUD over here (bout $1.05US) a litre, which is $3.98US per US Gallon, Quote Link to comment Share on other sites More sharing options...
Confused Posted September 8, 2005 Share Posted September 8, 2005 Quote How much you guys paying for fuel in the states' date=' Its just hit about $1.40AUD over here (bout $1.05US) a litre, which is $3.98US per US Gallon,[/quote'] Thats pretty much spot on what we pay. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted September 8, 2005 Share Posted September 8, 2005 Up here in Alaska the cheapest I've seen is $2.61, but on average its $2.69. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted September 8, 2005 Share Posted September 8, 2005 The lowest I've seen in GA is $2.86 right now Quote Link to comment Share on other sites More sharing options...
Phantom Posted September 8, 2005 Share Posted September 8, 2005 93 Octane just dropped to $3.10/gallon here in the DFW area from a high of $3.30.I'm amazed at you guys that get in the high 20's on the highway. Even at it's best my 77 280Z with an '83 NA drivetrain never did better than 25 which is about the same at my LS1. Then again, it had the stock Nissan ECU and maybe the aftermarket ones can be programmed to be more efficient? Quote Link to comment Share on other sites More sharing options...
envmyz Posted September 9, 2005 Share Posted September 9, 2005 got 30mpg on my way down to indianapolis this past month...cruising at 75-80 the whole way Gotta love the MS'n'S Extra.... Quote Link to comment Share on other sites More sharing options...
SonOfZZZap Posted September 9, 2005 Share Posted September 9, 2005 Up here in Dalton, GA Its about 2.60 for regular... prices are getting better, Ive only seen em go down. -ZzZap Quote Link to comment Share on other sites More sharing options...
AK-Z Posted September 10, 2005 Share Posted September 10, 2005 I forgot toadd the there is no sales tax in anchorage. Its still $2.61 up here:D Quote Link to comment Share on other sites More sharing options...
Guest Z Draci Posted September 10, 2005 Share Posted September 10, 2005 My bone stock 1982 280ZX turbo got exactly 20mpg with just city driving. It got a hair better on the highway but I did not bother to do a lot of high speed cruising with it. I expect to get about the same when I transplant that engine into my 240Z. Logically, you can get better mileage if you retain all the EGR and Evap components because the 240Z is a whopping 500lbs lighter. Since I am going to remove those, I figure the fuel efficiency will be decreased back to that 20mpg. I almost forgot to mention that I plan on running with close to stock boost until I start doing more modifications. The Megasquirt system can be programmed to run in an "economy mode" where you can get over 30mpg on the freeway. It's a great investment if you know as much about EFI as most guys on this forum. (I walked away from this idea so that should tell you how much I know!) Quote Link to comment Share on other sites More sharing options...
