johnc Posted September 19, 2005 Share Posted September 19, 2005 A good 110v welder will do anything you need done in steel on an automobile. I weld for a living and I had a Miller 135 110v that I ddin't think I would need anymore. I sold it to Tim240z. A month later I needed a 110v welder do do some exhaust work at the track for a customer. On the way to the track I stopped at a welding supply place and bought a Lincoln 135sp plus. Both are very good welders when you use a gas bottle. Quote Link to comment Share on other sites More sharing options...
SSflyer Posted September 19, 2005 Share Posted September 19, 2005 Maybe I should correct myself since I've never used the Miller or Lincoln 110v machines. I'd expect anything made by the two companies (and probably Hobart) to be useful. The 110v units I've used were of unknown ancestry, most likely from overseas, and they were pathetic. The voltage & wire adjustments did pretty much nothing, and worst was the wire feed was jerky. I used a MM135 and CP200s for years and never had a problem. Quote Link to comment Share on other sites More sharing options...
johnc Posted September 19, 2005 Share Posted September 19, 2005 Ask Owen about his Craftsman 110v MIG welder... Quote Link to comment Share on other sites More sharing options...
240zV8 Posted January 1, 2007 Share Posted January 1, 2007 Maybe I should correct myself since I've never used the Miller or Lincoln 110v machines. I'd expect anything made by the two companies (and probably Hobart) to be useful. The 110v units I've used were of unknown ancestry, most likely from overseas, and they were pathetic. The voltage & wire adjustments did pretty much nothing, and worst was the wire feed was jerky. I used a MM135 and CP200s for years and never had a problem. I was just doing some searching and I found that funny ^...lol...no disrespect. Quote Link to comment Share on other sites More sharing options...
Dunnie Posted January 7, 2007 Share Posted January 7, 2007 I can recommend the Clarke 130EN as I own one. It's a great 110v unit to learn with and the price is also very resonable too. Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted January 7, 2007 Share Posted January 7, 2007 Heh, heh... this thread is more than a year old:wink: Quote Link to comment Share on other sites More sharing options...
