TheNeedForZ Posted September 29, 2005 Share Posted September 29, 2005 I often find headers(for Datsun inline 6) for sale on eBay that doesn't include a Y pipe. Basically it should be 6-2-1 but without the y-pipe there is only the 6-into-2 section. I began to wonder if there is some sort of generic y-pipe that will fit ALL these headers. Without the y-pipe, these headers are useless or I am wrong. Quote Link to comment Share on other sites More sharing options...
johnc Posted September 29, 2005 Share Posted September 29, 2005 Normally you get one made by your local muffler shop or a race shop. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 29, 2005 Share Posted September 29, 2005 Or you could run dual exhaust... Quote Link to comment Share on other sites More sharing options...
DAW Posted September 29, 2005 Share Posted September 29, 2005 The nismo Y-pipe is a thing of beauty. Flowmaster sells junctions that are nicely made and will merge two 2 1/2" pipes into one 3", and from that you can taper down to a single 2 1/2" or 2 1/4". The stock 240Z exhaust is about sufficient for one set of 3 cyls., so you could get creative and bolt two systems together for dual exhaust, but the single is less fuss and less weight. DAW Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted September 30, 2005 Author Share Posted September 30, 2005 DAW said: The stock 240Z exhaust is about sufficient for one set of 3 cyls., so you could get creative and bolt two systems together for dual exhaust, but the single is less fuss and less weight. DAW I am not sure I understand what you mean? Don't all S30Z's come with stock manifold that is fitted to 6 cylinders and come out in one pipe? Quote Link to comment Share on other sites More sharing options...
