rudypoochris Posted October 12, 2005 Share Posted October 12, 2005 Hi this is going to be a super newb post seeing as i read through megasquirt.info and am thoughly confused. 1. What are Digi-Key parts? 2. What does the stimulator do? 3. How exactly does the MS box connect to the throttle body, injectors, and sensors? 4. What sensors do i use for a ford 302? 5. How difficult is it to program/setup for a v8 i have never run before? Is it possible to download a generic program for a ford 302? Thanks guys sorry if this has been answered 1,000 times, i searched but honestly i didn't even know what to search for. Quote Link to comment Share on other sites More sharing options...
dragoontwo Posted October 12, 2005 Share Posted October 12, 2005 1. Digi-Key is the place they reccomend you buy your components for the board from. 2. The Stimulator is a diagnostic tool for the ms. you can use it to check the function of the ms through the building process, or off of the car with this. 3. Either through a harness you build, if you know the wiring layout, you can connect most of the factory harness wires to it..... 4. any sensors that you want. you can run gm sensors if you don't want to mess around with easytherm, which will allow you to use the stock sensors. 5. I would try to find someone using a similar sized engine over on the MSefi Forums Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted October 13, 2005 Author Share Posted October 13, 2005 Oh wow, number 3 seems like a bitch. How am i supposed to know what all the wires going into the harness do? And furthermore how am i supposed to know where they need to end up on the MS board? Quote Link to comment Share on other sites More sharing options...
dragoontwo Posted October 13, 2005 Share Posted October 13, 2005 if you went through megasquirt.info, you should have seen the assembly instructions. the building of the harness should be in there also. and if you don't feel that you can build everything yourself, there are people that will build the boxes and the harness for you. the only thing that would really be left is the harness to your engine. Quote Link to comment Share on other sites More sharing options...
midnightzxt Posted October 13, 2005 Share Posted October 13, 2005 if you want a REALLY nice DIY harness kit, go to http://www.rs-autosport.com. I've got thiers and it was amazingly easy.. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted October 13, 2005 Author Share Posted October 13, 2005 Okay thanks guys. Last three questions: 1. Is there any one in the Bay Area running MS that can help me out? 2. How does the MS connect to the throttle body and injectors and what not by connecting tot he stock computer harness? Or by making a little harness to each piece? 3. Are there different types of harness connector available? Or do you simply take the old computers harness and yank all the wires out and put in your own? Quote Link to comment Share on other sites More sharing options...
midnightzxt Posted October 17, 2005 Share Posted October 17, 2005 1. Not sure 2. The wiring of the car is completely up to you, as long as it's done I have my car completely rewired for the system. I used the rs-autosports kit and the MS relay board. Pretty much the only connectors that you get to work with are the one that connect to the pieces, such as the injector connectors, sensor connectors, etc. WHen it comes to the throttle body.. I believe you need a variable sensor instead of a switch type.. meaning not the stock TB and prolly a 240sx one. Someone may correct me on this. 3. The MS is obviously connected to a DB-27 computer connection, which means you can't really use ony of the stock harness connectors. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted October 17, 2005 Author Share Posted October 17, 2005 Quote 1. Not sure 2. The wiring of the car is completely up to you' date=' as long as it's done I have my car completely rewired for the system. I used the rs-autosports kit and the MS relay board. Pretty much the only connectors that you get to work with are the one that connect to the pieces, such as the injector connectors, sensor connectors, etc. WHen it comes to the throttle body.. I believe you need a variable sensor instead of a switch type.. meaning not the stock TB and prolly a 240sx one. Someone may correct me on this. 3. The MS is obviously connected to a DB-27 computer connection, which means you can't really use ony of the stock harness connectors.[/quote'] You wouldn't happen to be running MS on a ford 302 would ya? Quote Link to comment Share on other sites More sharing options...
midnightzxt Posted October 18, 2005 Share Posted October 18, 2005 not yet.. that's for the VR conversion I'm doing in 6 years... just a boosted l28 Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted October 20, 2005 Share Posted October 20, 2005 i have ms running on my z with l28 but i work as a ford tech.you can screw gm sensors into ford manifold.if you are running 302 in a z with ms best to build all new harness with rs autosport kit.i used 1 and i liked it.i put magnets in my flywheel and triggered it with a hall effect sensor.iii wanted %100 new parts on my install and no old junkyard stuff.best place to learn is to read alot of posts on msefi.com.even though i have a 2 year college degree in electronics,ase master auto tech certification i still learned a lot on this install. Quote Link to comment Share on other sites More sharing options...
