dmanzo57 Posted October 23, 2005 Share Posted October 23, 2005 No distributor? No Problem! I sawed off an old points distributor to plug the hole and turn the oil pump. I need to find a cap to cover the spinning washer on the end of the cut down shaft. I made my trigger wheel by cutting notches in a unused belt groove on the crank pulley. I marked the pulley every 10 degrees and used a grinder to cut the notches. I know it's not 100% accurate, but I think it's close enough. It fired right up on the first try! I bought a set of spark plug wires for a 4.6L Mustang, but I don't like the way they fit. I need to find a set with 90 degree plug boots. Don Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted October 24, 2005 Share Posted October 24, 2005 if you know the theory about the way the parts you choose work you can do anything.i triggered my ms with a cherry hall effect sensor and magnets on the flywheel.but i still have a distibutor so you got me beat. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted October 24, 2005 Share Posted October 24, 2005 Good setup. I have been working with a guy to use a lathe and be able to index to make the nothes like you did. Since the lathe is already set up to provide the indexing you will end up with a higher precision if it matters for the notching. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted October 24, 2005 Share Posted October 24, 2005 Well, it makes sense that it would matter, how much I don't know, I think it would be alot easier to do on a mill rather than a lathe, but I do know about that indexing fixture. How many notches have to be in the pulley to work and how many degrees apart are they? I like the EDIS, and I'd like to try it. Quote Link to comment Share on other sites More sharing options...
dmanzo57 Posted October 25, 2005 Author Share Posted October 25, 2005 EDIS4/6/8 all use a 36-1 wheel. There are 36 teeth, one every 10 degrees, with one tooth missing to sync up the crank position. Here's a link to an excellent write-up on how it works... http://www.bgsoflex.com/mjl/mjl_edis_summary.html Don Quote Link to comment Share on other sites More sharing options...
z-ya Posted December 2, 2005 Share Posted December 2, 2005 Cool way to make the trigger wheel! On my supercharged L28 project I'm going to turn down the outer L28 pully so that the Ford trigger wheel fits with a slight interference. Then I will position it and weld it on. Quote Link to comment Share on other sites More sharing options...
Tony D Posted December 2, 2005 Share Posted December 2, 2005 What would the possibility be of simply turning off the notches on the stock 81 CAS trigger wheel, and renotching it to the current required configuration? This would give you a wheel that is indexed via a dowel pin from the factory, and transferrable to another pulley should the dampening ring fail (which it WILL DO given enough torque inputs on a turbo motor). Quote Link to comment Share on other sites More sharing options...
z-ya Posted December 2, 2005 Share Posted December 2, 2005 This is certainly doable. You would just need to place the missing tooth so that the sensor is 60 deg advanced from it at TDC. The super charger pulley is setup to use the 280Z damper, but I could make a spacer do that the SC pully aligns properly with CAS trigger wheel. Got an extra 81' damper with the CAS trigger wheel? Quote Link to comment Share on other sites More sharing options...
mobythevan Posted December 5, 2005 Share Posted December 5, 2005 I was just tossing this idea around for my BBC after watching this thread. I already have to run a spacer for my supercharger belt alignment. The spacer is a standard blower type (6 bolt 2.75" bolt pattern with 2" pilot hole). That is interesting because a guy on ebay already sells a machined 36-1 trigger wheel with a 2" pilot hole. So I would just have to machine down the spacer by the thickness of the trigger wheel and I could easily bolt this on. I have an old opints dizzy to cut off like dmanzo did. It always starts like this, now I have another thing to add to the list. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted December 5, 2005 Share Posted December 5, 2005 I went ahead and ordered the trigger wheel since we have a metal lathe at work. My buddy can machine the spacer to fix the thickness issue. Looks like its EDIS for me. Quote Link to comment Share on other sites More sharing options...
dmanzo57 Posted December 6, 2005 Author Share Posted December 6, 2005 I ended up buying a Mallory oil pump drive/distrbutor plug. The cut down distributor should have a bushing installed just below the cut. It was easier for me to just buy the whole assembly from Summit Racing. The car has been running flawlessly since converting to EDIS8. I hit 6400 RPM at the drag strip and it never missed a beat. Ran a best of 11.30@123.8 MPH. Don Quote Link to comment Share on other sites More sharing options...
z-ya Posted December 6, 2005 Share Posted December 6, 2005 Great to hear another EDIS sucess story. Nothing beats direct fire crank triggered ignition for blown or high compression applications. It really the only way to do it with Megasquirt, and it is cheap and simple to wire up. I'll post results when mine is up and running. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted December 6, 2005 Share Posted December 6, 2005 Nice solution with the mallory plug. Quote Link to comment Share on other sites More sharing options...
