help im going to buy wheels any suggestion
look okay.. no lip, no real good offsets come in that wheel for the Z.
i have a set on my FC and had them on a Z32 of mine.
great wheels but i dont no on a old Z.
mike
I think if you contact RAY'S directly you may discover you can have them done specifically for you.....offset and lug pattern. Of course it will cost more and take longer to get. Alot of the wheel manufacture, if contacted directly, will build you a set of wheels to your requirements. Yah, a set of bronze TE37 on a lowered early Z would look very good. Maybe 17's or 18's!?
What's your budget? That's the biggest deciding factor (other than preferrence) when it comes to wheels. RAY'S does custom make wheels but you have to expect ATLEAST a 90 day lead time (assuming they have nothing 'off the shelf' that will fit your expectations). They won't be cheap either. I had a set of Gram Light 57 Pro's custom ordered (zero offset) and they cost roughly $400 per wheel (in 18x8's).
Another thing to bear in mind... RAY'S does not offer custom offsets on ALL thier wheels. Where are you located? Call Glenn at Upgrade Motoring (818-998-6005 and http://www.upgrademotoring.com). He knows wheels and Z's (240's specifically) inside and out. He also imports RAY's products and can request custom wheels.
