Starter
oinojo
Can you turn it over by hand? First thing is to make sure that there isn't something seriously wrong with the new motor.
The turbo is lower compression so it should actually be easier to turn over than a non turbo. If the engine is fine and the starter won't crank it over you need to start diagnosing the usual issues there. Battery, battery cables, connections to the starter, ignition switch, and a bad starter itself are the most common causes for your problem.
Did this happen with the old starter? Did you use the starter off of the ZXT engine or the original? If this didn't happen with the old engine and just started happening now, then I'd start looking at connections and cables. Anyway, fill in some of the blanks and we might be able to help a bit more.
