Anyone running the Tremic T56 trans?
Bimmerman
I had a tech article published on the web a while back with step by step on what you needed for doing this with a Pre-86 block Chevy, using the 93-97 Camaro T56 tranny and all the related supporting parts... However, I can't find the orininal (Probably lost in bit heaven) and can't locate it on the web anywhere... It can be done, and the only issue is using a specific flywheel from Centerforce (153tooth) for the two piece rear main and getting the plumbing for the hydraulics together...
Mike
Pop, You are correct in that the Tremec T56 in the LS1/LS2/LS6 based vehicles is the same tranny, but required a different setup altogether because of input shaft length issues and bellhousing depth issues...There is an adapter kit out there made by a few different companies, but the best solution is to find the 93-97 setup and go with the appropriate flywheel for either the two piece rear main, or the one piece rear main, depending on your block configuration.
Mike
http://www.sallee-chevrolet.com/frame.html?/BorgWarner/bwt56.html
TREMEC’s GM aftermarket replacement T-56 six speed is designed to replace the T5 five speed in the 82-92 Camaros and Firebirds. This transmission can be used for many other applications with small modifications.
Installation is not as hard as you might think. Use the links in the Tremec T56 Navigation bar to help you understand what it will take to do the installation.
Yea but you never know if it is good one or not and how much abuse it has had. Plus the parts to make it work with an older engine are very costly. Just the adaptors to bolt it up are $600-700. Then it requires a specail flywheel that is around $250-300. And then you still need all the other parts which cost about another $450-650.
So on the low end you have at least $1300 invested to get a trans bolted up that may or may not be good. The tremec is cheaper because the trans is $2200 and all the other parts together to get it bolted up can't be no more than a couple hundred and you have a brand new trans with warranty.
