Beating the Firewall
v80z
I don't have a problem with clearance against the firewall. I used the JTR mounting kit and slotted the mounting holes as per JTR. Because of the transmission I'm running (200r4), I have the engine pushed as far toward the radiator as I could get.
With the tranmission crossmember flush with the bottom of the floor pan, there was no room for the tranny cooler lines and that required a bit of sledge hammer engineering.
Fitting an exhaust up tight required even more pounding away.
I haven't seen pics of anybody that had to mash the firewall.
Check out the member gallery section. There are a lot of good pics to give you an idea.
I did not have to touch it, the T56 with bellhousing was too big to get any closer than 1" from the firewall to the (non-hei) dist. the car lowered 1/2" front and 1/2" rear with alum heads, alum waterpump, intake, etc. So It was a well balanced addition of weight. I tried to install with the engine mounts right in the center of the original holes drilled out to 1/2" but had to slot them 1/2" forward to accomodate "issues" with the big bellhousing.
