Question: Illumina strut cartridge shaft thread size???
I am assuming that the Illumina cartridge shaft for the Z cars are all secured by a 12 mm x 1.25 nut...I am fabricating camber plates and it appears the VW Jetta and Z strut shaft threads are different in diameter. Since I will be using camber plates that require a 12mmx1.25 thread (lug) nut, I will not section the strut tubes 2 inches. and therefore my question is : are the Illumina threads the same as the stock Z strut shaft threads (12mmX1.25 RH). ..my camber plate fabrication link: http://forums.hybridz.org/showthread.php?t=106293
  • 5 months later...
I stumbled upon your post while searching for a solution to my problem. I have sectioned struts and I'm running Illuminas up front from a VW #1073. And you are correct, the VW shaft are a bit bigger and the threads on top are 14x1.5. This has been a huge PITA for me because now I'm trying to install GC camber plates and they are not working. I have got some info from a member here but I have got ZERO support from CG. They only thing worse than CG's install instructions is their CRAPPY customer service. Anywho, if you have a solution for this problem I'm all ears and ready to buy in on it.
jaime
Yeah, I hear ya Jon. I called GC the same day I received my plates. When I placed the order I mentioned that I had VW struts in the front. The guy assured me they make a part referred to as their "VW adapters" specificly for this application (Z car w/ VW struts). Well when my box arrived, not only were the adapters missing but the instructions were too. I have been on the phone with the guys at GC for the past 2 weeks trying to get things straigthened out with them but they have made the choice to blow me off and tell me lies. *** rant over ***
The part the told me about sounds alot like what you have described. Did you have to get a new tapered nut (14x1.5) to fit the top of the VW struts too? I'm thinking I could probably hand make the parts myself....maybe. Does anyone happen to have a pic or sketch on the adapters in question?
Sorry to hijack the thread........
Thanks Jon! I have been tooling around with it trying to make it work. I may have found something I can use as a shim but I will need to cut it down a bit. I think it just might work using the Tokico nuts. Thanks for the info. I will never buy from GC again!
