gexgexgexgex Posted November 28, 2005 Share Posted November 28, 2005 I got my megasquirt and spark extra all hooked up and the car runs. It just needs to be tuned. I just bought a wideband with controller and gauge. So i know what my Air Fuel Ratio(AFR) is and thats good, but when i try and feed teh wideband input to the megasquirt all it does is read 4.8 AFR. Iknow that that is wrong. But i can go into the Read Time Display and get teh voltage teh wideband is feeding into the megasquirt and it is correct, the same as the gauge. What settings do i have to set up, i looked on the website and it said to set the EGO thing to 2.500 volts and set ti to wideband. I did that and it still does nothing, just stays at sround 4.8 AFR. I even tryed different numbers for teh EGO volts, like 5.000, 1.4700, .4000 etc. by the way i have an LC-1 wideband controller I really want the megasquirt to help me tune. also how do you guys datalog with the megasquirt, i tryed the one under files-datalog-record but it does not work Quote Link to comment Share on other sites More sharing options...
mobythevan Posted November 28, 2005 Share Posted November 28, 2005 I thought you need to go into the .ini file and un-comment the line that selects you type of wideband so the megatune will use the correct calibration/setting file. Something like that, but I haven't looked at it in a long time. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted November 28, 2005 Share Posted November 28, 2005 if you figure out how it works let me know!! I will be buying a Wideband soon.. and I dont know how to do it! Quote Link to comment Share on other sites More sharing options...
dmanzo57 Posted November 29, 2005 Share Posted November 29, 2005 You can set your O2 sensor type in the MegaTune settings.ini file, in the mtCfg folder. There are two choices for Innovate WBO2 sensors. For datalogging, use File-Datalogging-Record, or Alt-L. Don Quote Link to comment Share on other sites More sharing options...
midnightzxt Posted November 29, 2005 Share Posted November 29, 2005 you can also set the type in megatune. You are having the same problem I had with the LC-1. Check to make sure you are using the correct analog output on the LC-1.. there is one out put for narrowband type on the other output for wideband type. Just check to make sure you've got the correct one first. Quote Link to comment Share on other sites More sharing options...
gexgexgexgex Posted November 30, 2005 Author Share Posted November 30, 2005 Thank you guys very much, i have everything working now i had to go into the car1 folder then to settings and pick the correct wideband, i picked the one that said, 10-1 afr=1volt, 20-1 afr=2 volt and i found out why my dataloging was not working, i did not have excel installed on my old laptop so it did not know what to do with the file. also where in the megatune instructions does it talk about all the settings for EGO, and what they all do so i can have it auto tune Quote Link to comment Share on other sites More sharing options...
boostin280zx Posted December 2, 2005 Share Posted December 2, 2005 I just got my LC-1 hooked up 2. I have ms2 and in megatune the a/f gauge did the same thing. I had the inovate wideband slected. I changed it to the DIYautotune widband and it started working. Its still not letting me use af tables. I haven't tried changing the .ini file yet b/c i pulled my motor out to rebuild, so ill do that and see if it works. Quote Link to comment Share on other sites More sharing options...
